My $7000 software with the $1000 a year maintenance has been a real poop sandwich for the last year or so.
Installed, good to go. I had looked in Connection Client around noon, update did not show, went to Fulfillment Center, downloaded, failed install, booted, failed again, eventually showed up in CC. Installed O.K. from there. Sheesh
My experience is to create a Deployment, run it in Full UI to investigate/ Discover bugs.
Then you can create a New deployment With no UI.
