I have been working on our Projectwise configuration for our CE upgrade from V8i.
We have been using a managed WS with CSBs in our current setup with V8i.
I have been following some examples on using a dynamic ProjectWise Managed Workspace with CSBs, and one issue I cannot solve is I keep getting the following Alert message that i need to restart MicroStation when switching drawings from within the same workset?
All my workspace & workset variables get set properly. The dynamic workspace is working and all variables correspond to the Work Area of the drawing I first open.
But I get the alert when I try to open another drawing from within PW in the same folder.
Even if I create a new drawing in the active workset, it gives me this alert when I go to open it?
Gary
MS CONNECT Update 12
PW Explorer 10.00.03.262
FYI - I solved what was causing this issue.
Where I had imported new config files for the new CSBs, I had the following variable set:
MS_CELLLIST < $(_DGNFILE)
This line was causing the variable to be different for every file I opened.
Removing this line fixed the issue.
Gary Manuel
CE Update 12
PW 10.00.03.262
Answer Verified By: Gary Manuel
