I am using the remap process when saving down to V7 (must deliver to a client in V7). I have created a cvs file to handle the remapping and configured 'MS_REMAP_CVSFILE' to use this file. I am only interested in remapping levels. This process works great.
My only question..., is there a configuration setting which will select 'Apply Level Mapping' by default, rather than having to select this option each time?
Larry Durke
There is not but if you convert the files through the batch process utility you can set the setting for multiple files.
https://communities.bentley.com/products/microstation/w/microstation__wiki/8830/batch-convert-utility
