I need to create batch file scripts to install OpenBuildings Designer update 5 and Microstation CONNECT update 7. Does Bentley have these available or guidance with command line switches available to downlaod?
Perhaps the following will help:
https://communities.bentley.com/products/microstation/w/microstation__wiki/28704/microstation-connect---how-to-create-a-deployment-image
We dont provide scripts to install multiple programs but the above article does detail how to create an image that can be used in conjunction with various deployment tools.
To add to the link David posted, once a deployment image has been created for each application, all you need to script for installation is a command line to run the appropriate .EXE.
Please refer to communities articles about ConfigurationSetup.cfg for information about redirecting applications to networked Custom Configurations.
Marc
