can anyone tell me why this MDL error box pops up when opening AECOsim Building Designer v8i ss6 ....
this is the error, MDL Loader: Could not load application C:/PROGRA~2/Bentley/PROJEC~1/bin\fencepublisher.ma
thanks
Assuming the full path is C:\Program Files (x86)\Bentley\ProjectWise\bin:
a) Can you confirm whether fencepublisher.ma exists in that location?
b) see if either MS_MDL or MS_MDPAPPS configuration variables specify this file?
If the file is not present but is specified by your configuration (or by a ProjectWise manged Configuration) removing that specification should resolve the error.
If the file is present it may not be compatible with AECOsim Building Designer V8i SS6, I'm not familiar with that filename. Is it a third-party add-in?
Marc
I'm interested in know the answer as well. I have a user on Microstation CONNECT update 14 getting the same error
