Where can I find the Vector icons tools in MS CONNECT?
Martin Mendez said:Where can I find the Vector icons tools
Vector icons are redundant and no longer included with MicroStation CONNECT. Use Windows icons instead. There are plenty of tools, freeware and paid, that let you design your own.
thanks Jon.
got the vector icon working but now having a hard time applying them to the ribbon. see video below.
again, thanks for the help.
Marin,
Based on the video I would guess use imported bit maps(.bmp) for icons not icons(.ico). Bit map "icons" will appear correctly in the icon selector because you can still use them in old school tool bars, customized in the custom tools & tasks area of the interface. That said the Ribbon only supports icon files. Did these icons get brought over from v8i?
There are many free utilities out there to convert your bmp files into ico files I've had success with this one in the past.
https://icoconvert.com/
-Grant
