The latest update has rendered all my networked Workspaces/Worksets inaccessible.Is there a setting somewhere I need to enable to undo this, or am I stuck rebuilding it all AGAIN?
what product and what version do you mean?
With regards,
Jan
Microstation Connect edition update 13, version 10.13.01.01
And what did you update from? For v8i to Connect there is a wizard. Sort of works, but you may need to copy some files/folders or even modify a couple configuration variables.
I've already used the migration tool to set up a workspace using the assets from our old V8 setup.The update that went up over the weekend has made all of our networked workspaces/sets inaccessible from Microstation itself. all the files and resources are still in place on our server, but the workspaces are not found when I open Microstation.
B.Chalker said:Is there a setting somewhere I need to enable to undo this
it's hard to guess when it's not clear how the workspace was structured, especially how the redirection (and in what configuration file) was done.
Bentley recommend to do this redirection in WorkSpaceSetup.cfg, where such setting is prepared by default, but not active.
B.Chalker said:all the files and resources are still in place on our server, but the workspaces are not found when I open Microstation.
Maybe WorkSpaceSetup.cfg was overwritten? General rule for any customization is to have backup of customized files. I guess they do not exist in the discussed case?
Some articles about CONNECT Edition workspace configuration exist (see e.g. this wiki) and they are useful source of information what to check. I also recommend to debug workspace configuration to know how exactly and using what configuration files the workspace is built.
