Hi
I am trying to convert a MicroStation select series 3 workspace into a a work set for connect edition.
I have tried using these methods https://communities.bentley.com/products/microstation/b/microstation_blog/posts/migrating-v8i-projects-to-microstation-connect-worksets
but it hasn't pulled through anything, it is a workspace for VicRoads, my main concern is linestyles/symbols/cell library's
any one 1 have work around or ideas?
Hi Adam,
The answer could be fairly simple if you are concerned only with these resource files.
To test just copy the files into the appropriate folders in the example Organization/WorkSpace/WorkSet structure, e.g. CEL files into C:\ProgramData\Bentley\OpenRoads Designer CE\Configuration\WorkSpaces\Metric Standards\Standards\Cell. You should then see them alongside the other resources in the examples so can be confident they work.
We need to know more deatil about the context before advising you what to do next.
Marc
