Back in 2018, we primarily switched over to CONNECT. Recreated all linestyles, levels, etc. to give ourselves a correct clean slate. However, every project before 2018 still uses all the V8i fonts, linestyles, etc.
Is there a way to lock all files before 2018 to only open with V8i, while only allowing all 2018 and newer files to open in CONNECT? All users still have both versions because we still both, but I only want the older jobs to pull the older data. Any help would be great. Thanks.
I think your best bet would be through a bit of programming and making use of custom file properties:
Rod WingSenior Systems Analyst
there is a function similar to what you are looking for with ProjectWise.You can associate a file (DGN) to use a specific version of the product.
docs.bentley.com/.../GUID-57FDC273-FAAF-E51B-D8D0-ECE182B4DD21.html
Timothy Hickman
Main: 877 627 3772|
