I just installed SS10 microstation and ss10 inroads, I would like my user to have the application pull down to load inroads like ss2
there appears to be no MDL to load it ?. We have stand alone Microstation and inroads i need my users to be able to hop in and out of inroads without having to close microstation
or have to LOAD inroads from the start menu with a copy of microstation
i assumed the same for ss2 just rename the load_inroads. CFG file from
Load_InRoads_SS2=1 to
Load_InRoads_SS10=1
didnt work
any tips would be great
thanks
Karl Detrick
The ability to mdl load InRoads in MicroStation stops at SS2. With the changes in OpenRoads technology in SS3 that option is no longer available.
Rod WingSenior Systems Analyst
I might also suggest that you transition to PowerInRoads SS10. It should use the same license as InRoads. PowerInRoads is both InRoads and MicroStation bundled together in one application. Going to OpenRoads Designer in the CONNECT release it is a similar packaging of the two together. There is no OpenRoads Designer add-on to install on top of a "regular" install of MicroStation.
