We have dgn files in folder that have an AECOsim Building Designer Managed Workspace config applied. These fiels are used with Microstation CONNECT Update 7/Bentley Facilities Planner CONNECT. When a user opens one of those as "read only", we get a dialog regarding the file not opening in any Workset/ There must be a variable that can be set to default to opening with no Workset. Any ideas?
Design files are branded with their Workset to break this association see https://communities.bentley.com/products/microstation/w/microstation__wiki/32023/how-to-break-the-association-between-certain-files-and-a-specific-workset
When launching the application from a shortcut the following command line switches can also be used including -wk<WorkSpace> and -ww<Workset> https://communities.bentley.com/products/microstation/w/microstation__wiki/8873/microstation-command-line-options-and-switches?CommentId=66212edc-9b8b-42d6-a02e-5c158d162552
Carl Myhill
Technical Support Engineer
Bentley Systems
