How can I download the V8i Configuration Explorer App? We still use V8i on older projects and occasionally need to go in and config. Plus the new App never works on our network and throws a ActiveX error.
Apologies in advance, but I've never understood why folks use v8i for older projects. Older CAD techs, yes, but the files are all the same. You may as well figure how to accomplish those common tasks in Connect.
I will have to check to see if a download is available.
The current version is is built to work with the CONNECT Edition and cannot process the old configuration files used by V8i you can refer to the following:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/194443/configuration-explorer/576635#576635
David, I'm still looking for version 08.11.09.26 if you have it. Thanks.
We're just checking availability of the V8i version.
Can you tell us more about your CONNECT configuration and the error you mention above?
Marc
