When I start MicroStation (CE Upd.13) the recent files will show in the Work Page. In the Work Page there's also a "Browse" button to find another file. When I hit the "Browse" button it will open in the recent used folder (that's controlled and stored by the user preference file).
I some cases I have placed a shortcut to start MicroStation in a specific folder and I would like the "Browse" button to look in that specific folder (using fx $(_WORKDIR)). So I'm seeking a possibility to control in which folder the Browse button will open ...fx a variabel similar to the one when browsing for references: MS_REF_DEFAULTATTACHDIRECTORY. ...it could be MS_DGN_BROWSE_DEFAULTDIRECTORY :-)
In other words: I want to be able to ignore the recent folder stored in the user preference file and use a variable to control the "Browse folder". I know the presences of MS_DEF and _USTN_WORKSETDGNS but as far as I can see they only "works" the first time a new WorkSet is chosen (afterwards the upf takes control).
The reason why I'm askinng is that I want to minimize the number of WorkSets or upf files.
Best regards
Anders
I've always used MS_DEF. Currently for CONNECT I have it set in my workset config. We have a separate workset for each project so I can have it open to the project specific folder. You could set it in the Client config and have it point to one specific client folder rather than project specific folders.
I'm sure there is another way to handle it, but I tend to stick with what works for me and is proven.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Hi mwlongThanks for your reply - unfortunately I can't see that MS_DEF helps controlling the folder (path) in which the Browse button will open (unless it's the first time you open a new WorkSet).
Sorry, I did not see you replied to this. For me, I can open a file with a selected workset. When I click the Browse button Microstation Manager opens to my project folder. If I go to Close and select a different workset & click Browse again Microstation Manager opens to my newly selected project folder.
This is an example of how I use MS_DEF in my workset configs.
_USTN_WORKSETDGNS = //engdat1/projects/5819_PA_PennDOT2_EngEnvl/01_Kinzua_Creek_Bridge_Repl/300_CADD/
MS_DEF = $(_USTN_WORKSETDGNS)
MS_RFDIR = $(MS_DEF)
Thanks for your new respond. As far as I can see (in my setup) the user preference file overrides the _USTN_WORKSETDGNS (or MS_DEF) variabel if I previously have opened a file in a WorkSet (the .upf remebers the last files and folders in the different WorkSets). So when I change the WorkSet the "Browse" button will always show the content of the last folder I have opened in the current WorkSet (not the folder defined in _USTN_WORKSETDGNS). It's only if I opens a WorkSet for the first time it will look into the folder defined in _USTN_WORKSETDGNS ...until now I thaught this was "Works As Designed". It's also new to me that your setup always returns to the _USTN_WORKSETDGNS folder when you change WorkSet (and not the last folder stored in the .upf "under" the WorkSet). Can you also confirm that when you start MicroStation, without opening a dgn fil, but first go to the Work Page (formerly MicroStation Manager) the Browse button will show you the content _USTN_WORKSETDGNS folder? ...in my setup it shows the latest used folder (in the current/chosen WorkSet) ...retrived from the .upf history.I have tried to define _USTN_WORKSETDGNS in the personal.ucf just to check if the definition order makes any difference ...it doesn't (the .ucf is the last .cfg file being read). In my setup _USTN_WORKSETDGNS is defined in the msconfig.cfg (default) which is one of the first cfg's which MicroStation reads....I'm curios why your setup apparently works different ...but I'll guess it's hard to find the reason, but thanks again for your interest ;-)
Anders W said:In my setup _USTN_WORKSETDGNS is defined in the msconfig.cfg
This file is read early when you start Microstation. You would need to override this location in you workset configuration file (project configuration) which is read later. In msconfig.cfg (which you should not edit) you can only set one folder location & it make sense that Microstation would look to that folder when trying to open new files. My _USTN_WORKSETDGNS is set in my project configuration. For each project configuration I have _USTN_WORKSETDGNS defined to MS_DEF. MS_DEF is then set to my project folder location.
If all of your project worksets are in one central location you could set _USTN_WORKSETDGNS higher up and have it point to that location the set MS_DEF to = $(_USTN_WORKSETDGNS)<project specific folder>
It is tough to diagnose & provide a specific resolution since these configurations can be modified in so many different ways.
