How to control the folder for the "Browse" button in the WorkPage?
When I start MicroStation (CE Upd.13) the recent files will show in the Work Page. In the Work Page there's also a "Browse" button to find another file. When I hit the "Browse" button it will open in the recent used folder (that's controlled and stored by the user preference file).
I some cases I have placed a shortcut to start MicroStation in a specific folder and I would like the "Browse" button to look in that specific folder (using fx $(_WORKDIR)). So I'm seeking a possibility to control in which folder the Browse button will open ...fx a variabel similar to the one when browsing for references: MS_REF_DEFAULTATTACHDIRECTORY. ...it could be MS_DGN_BROWSE_DEFAULTDIRECTORY :-)
In other words: I want to be able to ignore the recent folder stored in the user preference file and use a variable to control the "Browse folder". I know the presences of MS_DEF and _USTN_WORKSETDGNS but as far as I can see they only "works" the first time a new WorkSet is chosen (afterwards the upf takes control).
The reason why I'm askinng is that I want to minimize the number of WorkSets or upf files.
Best regards
Anders
  • Anders,
    As far as I can see we would need to make changes. In V8i folder paths listed in the PCF under MS_DEF would be added to the Folder History pop-downs in addition the the 10 entry personal MRU list.
    This is still the case for file dialogs in CONNECT Edition that currently continue to use older dialog designs with these file/folder history drop-down menus at the top right. Adding MS_DEF path definitions to the WorkSet.cfg will include them in the MRU list. The new dialogs with the file/folder history drop-down menus above the filename field do not do this.
    If you would find this useful please file a service request mentioning Enhancement 1093851.
    Marc
    Answer Verified By: Anders W
  • Hi Marc
    Thankyou very much for your reply on this subject. It confirms me that this isn't possible in the current "state" of MicroStation CONNECT. In the meantime I have managed to persuade my client to start MicroStation in another way (adding the WorkSpaces and WorkSets in the HKEY_CLASSES_ROOT\Bentley MicroStation Design\Shell.. Reg.key). Therefore they just needs to double click at the dgn file when they are running their default WorkSpaces/WorkSets.
    Therefore I wont file a service request ...but I'm happy to hear that you do have plans for "renewing" the old dialogs and the corresponding configuration variables :-)
    Anders
  • Anders
    One thing that I failed to mention is that we use a workspace switch in our Microstation shortcut. When I right-click on my CONNECT icon this is what the target looks like
    "C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe" -wr\\engdat1\COMMON2\MSV8i_support\Workspace\standards\
    This path is where we have a workspace stored for some legacy projects that we are finishing the drafting tasks using CONNECT. Maybe something like this will solve your issue?
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • Hi Anders W,
    I realize this is an older post, but wanted to put my thoughts in here as well.
    Try setting MS_FILEHISTORY = 0 in your configuration. This will prevent MicroStation from remembering the file history and will indirectly control the location of the Browse dialog as you desire.
    I believe you could use this to "reset" the location of the Browse directory.
    HTH,
    Jayson
  • Hi Jayson
    Thanks for your reply ...better late than never :-)
    I've tried setting MS_FILEHISTORY = 0 and now MS_DEF / _USTN_WORKSETDGNS "works" and control the path to the folder when I'm using the File Open dialog or the browse button in the WorkPage.
    But you can't satisfy everyone, cause when setting MS_FILEHISTORY = 0 it obviously means that the file history is empty and that isn't my intention :-(  In "my dreams" I want to keep the file history AND control the "file open path" but I guess this will require a new configuration variable or something other.
    So we should ask Marc for some info and status about this:
    Best regards
    Anders
