I have been exploring the use of worksets (not convinced yet!!) but how do I create a Workset Template, that when used, creates specific files & folders?
I have had a look through Help and this forum but can't find anything that explains the process of creating a new Workset Template.
stuartw said:I have had a look through Help and this forum
The Administration Forum might prove more fruitful.
Jon Summers said:The Administration Forum might prove more fruitful.
Not really. Had a search through that one and didn't get any hits to answer my question.
Is this possible?
When you create a WorkSet via the gui it is possible to add folders/sub folders to the WorkSet Standards
This new WorkSet ( in this case 'WorkSet Template' ) could be used as a Template when creating new New WorkSet and the same folder Structure will be used.
Note : in the image above the 'Create Folders Only' is checked so files in this instance will not be copied
The _USTN_WORKSETSTANDARDS & _USTN_WORKSETSTANDARDSUBDIRS variables could also be used.( See first Image )
See also Blog series
Carl Myhill
Technical Support Engineer
Bentley Systems
Carl, Thanks but that doesn't give me the results I want. When creating a new workset I want something like the following created which includes folders and files.
I don't need the dgn or standards folders or the other sub-folders.
How would I do this?
