[CE] NoWorkSet macro definitions
Why does the C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\NoWorkSpace\NoWorkSet.cfg file clear out the any previous Macro and VBA definitions?
# Set the macro creation and search paths.
MS_MACRONEWFILEDIRECTORY = $(_USTN_WORKSETROOT)
MS_MACRO = $(_USTN_WORKSETROOT)
MS_VBANEWPROJECTDIRECTORY = $(_USTN_WORKSETROOT)
MS_VBASEARCHDIRECTORIES = $(_USTN_WORKSETROOT)
At the application level I've added a .cfg file that defines the location of custom macro files setting the MS_MACRO and MS_VBASEARCHDIRECTORIES variables. If someone selects the NoWorkSpace option the above config file blows that away.
Shouldn't those variable definitions NoWorkSet.cfg file use the < or > operators instead?
