I am creating a Custom Workflow for one of our offices. This is for ORD, so its a little behind in release numbers to CONNECT.
I wanted to add the Geometry tab to my workflow and then remove the Vertical Group from it.
My first efforts seemed to work, but I subsequently discovered that I had removed it from all workflows that use the Geometry tab. I did eventually discover the "Import Local Cop" right click menu. But it seems like you have to first Add, Import Local Copy and then remove the Added version to get a copy that if customized is only within the current workflow under construction. And sometimes, I could not seem to remove the originally added tab.
This should not be this convoluted.
