We use Several V8i products with a networked workspace. Each product has a couple of configuration variables that need to be tested and included if that is the product to be used.
As in%if $(_ENGINENAME) == Microstation...%endif
But that line is giving me an "operand mismatch" error.
Can anyone help me understand what's wrong?
Your syntax is wrong. Try this...
%if ($(_ENGINENAME) == "MicroStation")
Rod WingSenior Systems Analyst
Answer Verified By: MaryB
Yep, that was it! Thank you.
MaryB
