When ProjectWise (PW) Explorer client is installed it puts configuration file pw.cfg in MicroStation's config/appl folder. That configuration file instructs MicroStation to pop the PW login dialog when it starts.
pw.cfg
config/appl
But how do I prevent MicroStation from showing that PW dialog? I have only one project (workset) where I want to use PW. Most of my work does not require PW.
MicroStation CONNECT Update 14.2.
Just uncomment the following row in pw.cfg:
PW_DISABLE_INTEGRATION_FROM_DESKTOP=1
/Krister
Owner consultant at Surell Consulting AB
Krister Surell said:Just uncomment the following row in pw.cfg
Thanks! But that disables PW for all MicroStation workspaces. How can I enable PW for the one workspace where I must connect to PW?
Didn´t test it yet, but what about putting variable into cfg-files of respective workspaces?
That sort-of works. On starting MicroStation, I still see the PW log-in dialog, which then vanishes. I would prefer that PW Explorer not load at all.
This is kind of an ugly solution, but move the file pw.cfg in MicroStation's config/appl folder somewhere else so MicroStation does not automatically read it. Then in the one WorkSpace configuration file you need ProjectWise do a %include to the pw.cfg file.
Rod WingSenior Systems Analyst
