To start I would like to note that I'm just the IT guy and my experience with MicroStation is limited to none. Where do I need to put my files so they will populate the drop-down list in the CONNECT configuration assistant tool? I launch Connect, click file, click settings, click configuration assistant, configuration assistant opens, but the select V8i workspace drop-down is empty. There is no information provided in the program about where the program is looking or which files it is looking for. V8i was installed with all of the default values (IE file paths), so if the tool is looking in a default location it should see the files. Is there a way to export the workspaces from V8i SS2 to a format that Connect edition can handle? V8i SS2 is the version we have available. We don't have access to newer versions of V8i. We do have access to the older V8 but I doubt that will help in this situation.
It would appear from your images above that you have V8i installed, although this might not be the case and the files are left behind from a previous install.
Do you have MicroStation V8i installed and configured on this PC and is it finding the v8i WorkSpace ok ? If not please install and configure you Workspace, then try the CONNECT Configuration assistant again to see if its selectable.
V8i is not and was never installed on this test system. I copied the files from a user's system to that location on the test system. Is having V8i installed a requirement for using the config assistant in the Connect edition?
Thank you for the confirmation, it is currently a requirement to have V8i installed/configured.
However as there may be instances as in your case where V8i is not installed, Enhancement Request 1112240 has been filed requesting that the Configuration Assistant have the ability to read V8i Workspace without the application. This is targeted for Update 16
Answer Verified By: Michael Elias
I might suggest you configure your new install manually. Does require a bit more knowledge.
Michael Elias said:Is having V8i installed a requirement for using the config assistant in the Connect edition?
