I'm was trying to capture the WorkSet Description in a WorkSet configuration file, turns out there doesn't appear to be one.
There is one for the WorkSpace: _USTN_WORKSPACEDESCR
and one for the User: _USTN_USERDESCR
but there does not appear to be a _USTN_WORKSETDESCR variable that displays the WorkSet Description value.
Is there any way to get the WorkSet Description in a configuration file?
does it need to be a config variable ?
There is a "description" property for the workset - would this be something you could use ?
Timothy Hickman
Main: 877 627 3772|
It has to be something I can access from a configuration file.
Rod WingSenior Systems Analyst
