I need to develop a custom WorkSet creation tool as there aren't enough options in the MicroStation dialog to suit the needs of my client. They would like project/WorkSet creation to be done by an Office Assistant without the need for MicroStation. Copying and renaming a template WorkSet.cfg and WorkSet.dgnws to the correct WorkSet name works except when in comes to the Sheet Index.
When I open the Sheet Index it has the name of the original template WorkSet name, and all of the editing options are missing.
In the example below project 1 was then name of the template WorkSet. I created a WorkSet called project 2 by copying and renaming all of the project 1 files to project 2, including the .dgnws file. The image below is what the Sheet Index looks like in project 2.
I've verified the _USTN_WORKSETDGNWS variable, and setting custom WorkSet properties that the project 2.dgnws file is being accessed.
Is there any way to update the Sheet Index?
Hi Rod. Thanks for posting. We will keep you updated on the progress of this defect via email through your Service Request related to this post (SR # 7001150109).Thanks,Jayson
