Hi
I've made some changes to where microstation looks for workspaces and worksets. It works great except when I create a new workset. I have to restart microstation for the new workset to be visible. How can I solve this?
Robert
Can you post your configuration file where those variables are being defined?
Also, at what level in the configuration is the configuration file being loaded (System, Application, Organization, etc)?
Rod WingSenior Systems Analyst
In my organization's standards.cfg-file I've put the line:
_USTN_WORKSPACESROOT = R:\Bentley\Workspaces\
Have you tried using the _USTN_CUSTOM_CONFIGURATION variable?
Set _USTN_CUSTOM_CONFIGURATION = R:\Bentley\ in C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg.
Then you don't have to set _USTN_WORKSPACEROOT.
To use that you will also need an R:\Bentley\Organization folder, or remap _USTN_ORGANIZATION to a different folder.
When I set up custom configurations for clients I typically have a "Startup" configuration file that gets loaded early on in the sequence that sets _USTN_CUSTOM_CONFIGURATION. I don't modify any the default files delivered with MicroStation as that can lead to other problems when the client upgrades, or reinstalls.
Something like this....
# Override default location of custom configurations as defined when ORD was installed_USTN_CUSTOM_CONFIGURATION = $(_DOT_ORD)Configuration/%lock _USTN_CUSTOM_CONFIGURATION
I lock the variable so that the C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg file doesn't reset it.
Setting it up this way I have never run into the problem you are seeing.
Thanks for your reply Rod.
I actually have _ustn_custom_configuration set to a different location. The reason for this is a legacy from before my time, but the servers back then were not as fast as they needed to be. So the organization folder is mirrored from a server to C: on every computer log in, this way the files were always stored locally. This also meant the users couldn't change anything they're not supposed to change, or it would get overwritten on the next login, which has been a great benefit and is why we still go with this workflow.
But we couldn't use this for workspaces/worksets since users are writing data to those files. Not just reading. So the organiztion-folder and workspaces/worksets are separated.
I tried to set the workspacesroot-variable in the workspacesetup.cfg and configurationsetup.cfg, stored in "C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration" My thought was that maybe these files would be reloaded after a workset creation. But it didn't help.
Not sure what to try next.
I've had issues in CONNECT with creating dgnlib files, and them not being recognized until I restart MicroStation, but never the WorkSets.
Robert Högberg said:Not sure what to try next.
Without taking a deep dive into your configuration it's hard to say.That being said, I think the next logical place to look is your _USTN_WORKSETSROOT and _USTN_WORKSETROOT variable definitions. Both where in the configuration they are being defined, and the actual definitions.
