I am still trying to wrap my head around worksets. I can get this far:
MY_WORKSET_LOCATION = S:/Project Files/_USTN_WORKSETSROOT = $(MY_WORKSET_LOCATION)
I have a few problems, because this isn't quite right.
Our projects (which I envision to be our worksets) are actually stored in
S:/Project Files/2019/S:/Project Files/2020/S:/Project Files/2021/and so on.
This is regardless of client, department, etc. Everybody's projects go into this structure by project number which is year-project so that each project has its own set of subdirectories. I am not going to be able to convince the entire company to change how we store projects because the transportation department is switching to OpenRoads.
In addition to this, I'm probably going to have to back into our worksets because that directory structure is going to exist for a couple months before I get involved into the project. All of the administration, contracts, proposals and other front office work that go into that project get set up before the actual CAD starts up.
What's the best way to manage this, from a configuration standpoint?
Where is the configuration data going to exist ?
Timothy Hickman
Main: 877 627 3772|
Are these all going to be under the same WorkSpace or is that level being used to setup other resources such as client resources?
a possible solution would be to create a workspace for each year that are configured with the same resources. So on the workpage the user would select the year and then the project within that year.
At the Moment, Workspaces were going to be by client, and worksets to be by project.
Are you suggesting I have separate workspaces for INDOT-2019, INDOT-2020, INDOT-2021, INDOT-2022, CDOT-2019, CDOT-2020, CDOT-2021, CDOT-2022, etc? Even though all the INDOT workspaces would be identical, similar for the CDOT?
That's an overhead nightmare on some levels.
Why is it not possible to have a Workspace without a Workset?There are a few benefits to using Worksets, but I'm honestly struggling to see the value compared to the work involved in making them function within our company structure. This is the biggest problem, but I can see others (including "branding" conflicts when copying drawings from one project to another). We need the Workspaces for client standards, but Worksets seem to be more trouble than they are worth.
MaryB
The configuration data would be stored on our "Standards" drive, same as always. I want to keep my configuration data separate from production data - it minimizes the change of accidental deletion or moves. People are in and out of the S: drive all day, but nobody bothers with the M: drive unless they need something specific.
you need to look at worksetroot verses worksetsroot
if you store the project data by year and project number then why are you attempting to sort it by client ?
