I work in ProjectWise and have different customers with different fonts.
When I work offline I have one customers fonts I want to use for offline.
Is their a way to copy the fonts my administrator set up in ProjectWise so when I work offline MicroStation is still using those fonts?
Typically when I work offline then, ProjectWise comes back up I notice that my text is all messed up because working offline has corrupted my fonts for whatever I "thought" I fixed.
BR,
Nathan
Is below my font file: Or is their a different extension than .rsc for fonts?
Fonts are in RSC file, so that looks like the right one.
They can also be TTF or SHX, so you may want to copy both files over to your font directory
Which version of MicroStation are you using? That may affect which directory to put those files.Microstation CONNECT has a configuration variable MS_FONTPATH you can use to find the location of your other local font files.In V8i (SS#) I believe the variable you will want to look at is MS_SYMBRSRC.
MaryB
