I work in ProjectWise and have different customers with different fonts.
When I work offline I have one customers fonts I want to use for offline.
Is their a way to copy the fonts my administrator set up in ProjectWise so when I work offline MicroStation is still using those fonts?
Typically when I work offline then, ProjectWise comes back up I notice that my text is all messed up because working offline has corrupted my fonts for whatever I "thought" I fixed.
BR,
Nathan
If you do not know where or which fonts are used perhaps using the packager to gather the files may help:
How to ensure all files are gathered in Packager.
Once gathered you should be able to load the fonts to your local/offline workspace.
