MicroStation CE - Last used WorkSpace/WorkSet not being displayed
I'm having an issue in certain configurations where the last used WorkSpace and WorkSet are not being displayed when you relaunch MicroStation. It displays No WorkSpace and No WorkSet.
Checking my Personal.ucf file the correct _USTN_WORKSPACENAME and _USTN_WORKSETNAME are stored in the file. However they are not displayed as the defaults on the WorkPage.
I can reselect the correct WorkSpace and WorkSet, so they are being found.
This does not seem to be a problem with ORD using the same configuration. It also only appears to be a problem with WorkSpaces defined under Custom Configurations.
Anyone else seeing this, or have any suggestions?
MicroStation CE U15
ORD 2020 R3
Parents Reply Children
