I'm trying to understand how to use the WorkSet template. I've read in other posts others are using the template set by _USTN_WORKSETTEMPLATE.
_USTN_WORKSETTEMPLATE is set to the below. Is WorkSet.Template the correct file extension?
If so when I create a WorkSet the Template doesn't appear
The _USTN_WORKSETTEMPLATE variable doesn't work that way.
Check out my explanation here...
https://communities.bentley.com/products/microstation/f/microstation-forum/112743/workset-templates/628867#628867
Rod WingSenior Systems Analyst
Answer Verified By: Marc Thomas
We are looking at making this better, also watch out for some new stuff that should make this easier coming along as 2021 progresses...
Marc
