We are trying to streamline our workflow that alternates using DWG files in Microstation and AutoCAD, any tips or resources?
Thanks-
this may help:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v17/en/GUID-E68D82D1-0362-9E51-E47C-215A413F90CC.html
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Marc Thomas
This is helpful - thank you!
This area of the help documentation is well populated and will hopefully provide further insight:
Marc
Tips- Without a bit of forethought this can became a headache. I have some clients who want DWG files delivered back to them. I try to keep those in DWG. On some projects that get more involved I will convert the DWG to DGN. Just depends on your needs. If working in a DGN that I suspect will later need converted back to DWG, I set the configuration variable MS_WORKMODE to DWG, this keeps Microstation from creating things not compatible in Autocad. It's important to know in advance what will be expected at the end of the project.
