I am working in MicroStation CE Update15. I need to enable /disable ribbon menu buttons based on a variable value.
When i searched in community, many suggestions was can be done through "Named Expressions".
Please provide me an simple example using Named Expressions to achieve this.
Hi Jan,
Just experimenting Named Expressions using https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v17/en/NamedExpressions.html.
BTW Why you pollute the question by so many useless tags, not relevant to discussed topics, but at the same time do not follow the best practices, defined for this forum?
Hi Rajesh,
what is your current knowledge of Named Expression? Did you learn them from MicroStation documentation?
Jan
