I am customizing the ribbon in MS Connect. Before I go any further I want to make sure that I am able to push my changes out to other users so they are able to see my changes. What files do I need to copy to their machines?
if you use a standard user way, how the ribbon is customized, the customization is saved to personal.dgnlib, defined by MS_PERSONALDGNLIB configuration variable. To check where this file is located, use key-in expand echo $(MS_PERSONALDGNLIB).
When you want to create a definition, that will be shared with other users, maybe to use other DGNLIB would be better, because personal.dgnlib is intended as "personal store" of customization.
With regards,
Jan
Thanks Jan,
This helps a lot.
Manuel Cantu
Sr. Piping Designer / CAD Administrator
My next question is, how do I switch from personal.dgnlib to another customized file?
Mcantu59 said:My next question is
It's recommend (see the best practices) to ask new question in a new post and to do not hijack existing discussion.
Mcantu59 said:how do I switch from personal.dgnlib to another customized file?
I can imagine more scenarios, but I think to change the variable to point to another (empty) file, do the customization, and to set this file as GUI DGNLIB on other computers should work.
