Hello everyone, I have a question regarding loading custom UCF file during the startup of Microstation CE application(and also OpenCitiesMap/Advanced, OpenCities Map Ultimate).
Back in the days of V8I, there was an option to launch the Microstation with my own UCF file using the command line switch ws_USTN_USERCFG="myFile.cfg"... I made some investigation on this approach in this CE world and found out following :
My question is, how did you guys solve the situation to launch a given application but with your own UCF file? I mean, I was thinking about copying my files into the prefs folder and name them Personal, but that means my configuration will replace everything and maybe sometimes I want to use it without it. Then another problem is that every product has its own folder path, so basically I have to copy my UCF into the correct folder depending on the installed version (and then I also though about what would happen if the directory path changes with some new updates[right now its in Microstation\10.0.0\prefs] - another trouble!).
Or is there a better and easier way to achieve loading selected UCF during the startup?
Thanks for any suggestions.
well - just found out there is a defect filed for the "wc" command line switch.
defect #729779
Timothy Hickman
Main: 877 627 3772|
oh, thanks for checking that! is there a way for me to check the progress of this bug issue? whenever it gets some new information or gets fixed.
Lubo B said:is there a way for me to check the progress of this bug issue?
It was explained many times :-)
Create Service Ticket and ask the ticket to be linked with the defect number.
Jan
I use the -wc switch quite often, with no problems. One thing to note is that when using that switch the mslocal.cfg is not automatically loaded. Your custom config file specified by the -wc switch will have to do a %include of the mslocal.cfg
Rod WingSenior Systems Analyst
Answer Verified By: Lubo B
Hello, sorry for late response. I found quite a workaround, with macro USTN_WORKSPACEROOT and defining my own Workspaces/NoWorkSpace/NoWorkSet.cfg. It is working the way I want, but it is probably not the right way to do that.
You might be right, including the mslocal.cfg might be the thing im missing.
However, is it possible to use also some kind of generic way to include the proper mslocal.cfg ? In case of different applications (OpenCities Map Advances, PowerView, Ultimate...), they all have different folder structures and places where these mslocals are stored.
Edit: I have tried it and it works, after i included mslocal (with fixed path). Thanks! The remaining subquestion remains though, to retrieve the path of exe that is executed, so i know where to look for mslocal no matter which application is being called.
Edit2: Basically the directories are defined AFTER mslocal.cfg is included, like the path where configuration files are stored
