The MSCE Update 16 Help document now online introduces something called One Configuration.
"You can now manage your project standards with One Configuration. You will have the flexibility to execute projects with the choice of using your organization's standards, your organization's standards in combination with your client's standards, or client-only standards. One configuration works with WorkSpaces utilizing Configuration Sets that use various combinations of standards to meet your organization's needs. These Configuration Sets can be easily adopted by other organizations that you work with."
docs.bentley.com/.../GUID-68262C6B-CCE5-4FFE-8BCC-EF0175D82D46.html
Will there be more information forthcoming about how this works?
Isn't it too early to ask about the feature in not released product, based on not finished, not public documentation?
Jan
I too am curious about how this will work and if we can or should utilize it in our organization. Also saw the entry for pulling connect advisor out of the software in which I am glad to see also. seems to be closer to running as a stand-alone application.
As far as too early to ask questions, it should not be published if it is not intended to be asked about. It does indeed looks as though it is public documentation.
lilsweepr said:it should not be published if it is not intended to be asked about.
It's not publicly and was not published as standard documentation. MicroStation CE Update 16 documentation is not listed in the list of available documentation. Without direct link, you cannot reach it from official index of available documentations at web main page.
Gotcha, i understand now what you are saying but I have not looked in from the outside for quite a few years now.
Any info as usual will be posted on the announcements forum:
https://communities.bentley.com/products/microstation/f/microstation-announcements-forum#pifragment-25830=1
Once formally announced will be happy to answer any questions regarding this functionality.
