I am trying to configure ORD CE for ProjectWise.
Our folder structure does not support worksets under workspaces but there a videos on how to configure that. I have been successful in making out projects work as worksets and associating them with a workspace. However, my efforts to enable the sheet index (and whatever else a DGNWS file provides)have failed. I have defined a common location for the Workset CFG files and location where the DGNWS file should be created using _USTN_WORKSETSDGNWSROOT.
But I cannot figure out how to define _USTN_WORKSETDGNWS in PW. According to its description, it should be the full path file name of the DGNWS file. But in my PW Managed Workspace, it is being defined to the Workset name only and according to the Configuration Dialog box, it is being set at a System Level, While most of my workset variables at reported to be correctly set to Workset Level.
I discovered that if I list the Configuration Variables using the Show Configuration Variables command of the dialog box and compare its list to the Summary of Variables from an MSDEBUG.TXT file, there are a number of assignments that are missing. Particularly glaring is the _USTN_WORKSETDGNWS assignment. In fact, I have searched every CFG I could find and do not see it listed anywhere.
If it is automatically generated, are there rules and conditions that can effect its assignment? I need to figure out why I cannot get the variable and its operational purpose to function in Project Wise.
Tim, yeah, it works. BUT our worksetsroot folder is located within the WorkSpaces folder (<WorkSpace_Name>/Worksets) and since its on another drive and write locked, users can't write to it and taking away all the cool functionality of the DGNWS.
yepp - this was one of my arguments when this was first introduced.
Timothy Hickman
Main: 877 627 3772|
here is another DGNWS woe:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/217047/managing-sheet-index-dgnws-for-different-companies-disciplines-on-the-same-project
Hi Charles,
A defect titled "WorkSet Template Custom Properties not copied to new WorkSet" was fixed in MicroStation Update 14 (10.14.00.109). The description of this matches your experiences.
Which application versions are you using?
Marc
I think the DGNWS file gets the needed properties, but if it is located other than with the workset it doesn't get read. He stated that if he moved the created DGNWS file under the worksets folder then he was able to see the added properties.
BUT... if I copy the DGNWS file to the Workset folder, all the fields are present and works "as it should"
or am I reading it wrong ?
