I am trying to configure ORD CE for ProjectWise.
Our folder structure does not support worksets under workspaces but there a videos on how to configure that. I have been successful in making out projects work as worksets and associating them with a workspace. However, my efforts to enable the sheet index (and whatever else a DGNWS file provides)have failed. I have defined a common location for the Workset CFG files and location where the DGNWS file should be created using _USTN_WORKSETSDGNWSROOT.
But I cannot figure out how to define _USTN_WORKSETDGNWS in PW. According to its description, it should be the full path file name of the DGNWS file. But in my PW Managed Workspace, it is being defined to the Workset name only and according to the Configuration Dialog box, it is being set at a System Level, While most of my workset variables at reported to be correctly set to Workset Level.
I discovered that if I list the Configuration Variables using the Show Configuration Variables command of the dialog box and compare its list to the Summary of Variables from an MSDEBUG.TXT file, there are a number of assignments that are missing. Particularly glaring is the _USTN_WORKSETDGNWS assignment. In fact, I have searched every CFG I could find and do not see it listed anywhere.
If it is automatically generated, are there rules and conditions that can effect its assignment? I need to figure out why I cannot get the variable and its operational purpose to function in Project Wise.
Those are very good points and I agree with all of them. Working outside PW, the DGNWS file and the functionality that can be associated with it would helpful, especially when using fields in title blocks and all that.
In the past, I configured our workspaces to a central location distant from the actual project CAD files. This was done to have all our users resource standards from once central location (DUH!), prevent them from editing said standards and allow our IT folks to easily assign the necessary file access permissions. Its been a disappointment that even at Release 16, the DGNWS file still can't reside "outside the standard "Configuration" folders. At to your point, _USTN_WORKSETSDGNWSROOT is a variable that serves no purpose.
I filed an SR several months ago and it is indeed a defect (as they call it) Defect 1116741and its anticipated to be addressed in Release 17. 16 Releases too late.
I've been working on some non-ProjectWise configurations for users over the last few weeks and offer the following suggestions relating to the DGNWS.
The complete block I've put in WorkSpaceSettings.cfg is:
MY_PROJECT_SERVER = <path>/_USTN_WORKSETROOT = $(MY_PROJECT_SERVER)$(_USTN_WORKSETNAME)/_USTN_WORKSETSTANDARDSDIRNAME = <MyStandardsFolder>%lock _USTN_WORKSETSTANDARDSDIRNAME_USTN_WORKSETSTANDARDS = $(_USTN_WORKSETROOT)$(_USTN_WORKSETSTANDARDSDIRNAME)\ %lock _USTN_WORKSETSTANDARDS_USTN_WORKSETDGNWS = $(_USTN_WORKSETSTANDARDS)$(_USTN_WORKSETNAME).DGNWS%lock _USTN_WORKSETDGNWS
The variables are locked to ensure that other CFG files do not change them. OpenBuildings Designer for instance, to ensure that the delivered example WorkSets operate as designed, sets _USTN_WORKSETSTANDARDSDIRNAME = Standards.
In multiple WorkSpace scenarios where perhaps the root folder for the WorkSets vary, some or all of these could be put in the WorkSpace CFG.
The other interesting thing which may help, obvious in hindsight, is OOTB the configuration results in the folder structure: ....\<WorkSpaceName>\<WorkSetName>\ so WorkSets are always contained within a WorkSpace folder.
By redirecting _USTN_WORKSETROOT to a path that does not include _USTN_WORKSPACENAME as shown above, the WorkSets can be stored in any required location, while the benefits (if needed) of assigning differing resources by WorkSpace within the configuration are retained, and the grouping of projects in the UI is retained.
I'll post some examples over the next month, probably in my blog.
Hope this helps.
Marc
Answer Verified By: caddcop
Thanks for that explanation Marc.
A follow-up to this, our organization has several different disciplines and utilizes both Bentley and Autodesk apps. We have adopted a standard project folder structure and is standard across all these disciplines. Project folders are created to the production drive by our IT dept. using a script that automates the process (copying folders from a master and assigning permissions).
The Configuration folder is located on a "workspace drive". The workspace drive supports all our CAD products. We currently have basically 2 main WorkSpaces types, Corporate, Public client (ie PennDOT, WVDOH). The project folders are the same for both. Once the folder is created, if the project is using Bentley CAD apps, I create the projects workset files by just copying a master and editing a variable or two in the applicable WorkSpaces/Worksets folder. This process has always worked for in the past.
So following your recommendation, I edited my WorkSpaceSetup config file to the following
_USTN_WORKSETROOT = $(Client_Project)$(_USTN_WORKSETNAME)/_USTN_WORKSETDGNS = $(_USTN_WORKSETROOT)02 Draw/_USTN_WORKSETSTANDARDSDIRNAME = 02 Standards%lock _USTN_WORKSETSTANDARDSDIRNAME_USTN_WORKSETSTANDARDS = $(_USTN_WORKSETROOT)02 Draw/05 Application/$(_USTN_WORKSETSTANDARDSDIRNAME)/%lock _USTN_WORKSETSTANDARDS_USTN_WORKSETSDGNWSROOT = $(_USTN_WORKSETSTANDARDS)_USTN_WORKSETDGNWS = $(_USTN_WORKSETSDGNWSROOT)$(_USTN_WORKSETNAME).DGNWS%lock _USTN_WORKSETDGNWS
In my configuration testing sandbox, I created a NEW project workset in my corporate WorkSpaces/Worksets/ folder following my existing workflow.
Using MicroStation Connect, I selected the corporate WorkSpace and the NEW Workset..BANG, a NEW DGNWS file got create to the _USTN_WORKSETSDGNWSROOT location from the standard DGNWS template file that had all of my custom fields. Perfect! I closed MicroStation.
SO NOW THIS IS THE FRUSTRATING PART!
I re-launched MicroStation Connect, selected the same WorkSpace and Workset. The custom fields are no longer shown. I confirmed the DGNWS file IS in the desired location.
I created a new file to the "New" project. I the created another file in the same project and folder. I closed MicroStation.
I relaunched MicroStation, the Corp WorkSpace and NEW Workset stuck and the two NEW files I created were listed as associated with the Workset.
I added a couple of custom fields, opened a file then exited MicroStation, I relaunched MicroStation and the custom fields are gone.
So, it "Appears" that I was able to redirect the DGNWS file to another location, BUT it also appears that MicroStation really doesn't recognize it after the original creation of it. I've deleted and re-created the DGNWS several times with the same results.
BUT... if I copy the DGNWS file to the Workset folder, all the fields are present and works "as it should".
so you move the DGNWS file from the workset standards folder, to the actual workset root folder and then it works ?
I am having similar issues when trying to separate my engineering/working data from the configuration.
The other frustrating part on my end is the generic exception logs that get generated - not much help for me.
I can get the Bentley products to read the new locations and have no issues. My problem comes with the creation process for anything new. For some reason the creation process (for me) doesn't like the data being located outside of the Bentley directory structure.
but the both of us - as well as others - are not configuring things the exact same way - so it seems that Bentley has issues with us changing these.
Timothy Hickman
Main: 877 627 3772|
*sigh*Perhaps Bentley should have asked the user base how we normally store project information vs. workspaces?
MaryB
