The help page for the file open dialog shows the ability to select workspace and workset. But I can't see that option in the latest CE MS U15.2. Just wondering if that option is still available?
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v13/en/GUID-CE6CE92B-3D4E-098C-B83A-10FFEE5CC4E7.html
Best regards,
Tuan Le
Hi Tuan,
Thanks for raising this issue in the SR 7001253769. I will update you regarding this issue soon.
Best Regards,
Shivam Soni
For this issue please see the below steps that we perform to resolve the issue.
Step1>> Open the file in the MicroStation or OBD software.
Step2>> After opening the file go to the back stage and then Click on the Browse option and there you will see the option of workspace and Workset as shown in the below snap.
Apart from that we are attaching a video showing the workflow for your reference. Please let me know if this helps you
Answer Verified By: Shivam Soni
