Title says it all - can I run a repair on MicroStation CONNECT?This is an option in the V8i generation - I can select repair or modify. For CONNECT I only get the modify option
Tom F.
Tom Felcone said:This is an option in the V8i generation - I can select repair or modify. For CONNECT I only get the modify option
Are you going through the Windows Control Panel or are you running the installer?
You should be able to run the installer for the specific version you have and get the repair option see below:
Answer Verified By: Tom Felcone
David,
Thanks, I've been running it from the Control Panel
