Can a 3D connexion mouse be uses in Bentley software such as Microstation Connect, OpenUtilities etc.
Hi Johan,
Yes, we have some tools that help when using one:
3d Input Toolbox.To help control the SpaceMouse movements there is a set of tools, how they work is described in MicroStation help > Getting Started > Fundamentals > Graphical Input > Graphical Input with a 3Dconnexion Device.
To launch the toolbox either Ctrl +T to open the Toolboxes dialog, tick 3dInput, or key-in: VIEW NAVIGATION 3DINPUT TOOLBOX.
I find some adjustment of the default motion speeds is necessary when using mine
Marc
Hi Marc
I have the same 3D mouse mentioned by Johan but I use the MAXSURF suite. I have found zoom works but nothing else. The same steps you have mentioned I cannot find in the MAXSURF suite of programs. Is there a workaround or is this mouse not supported in these programs?
Perhaps the following might help:
https://communities.bentley.com/other/old_site_member_blogs/peer_blogs/b/marc_thomass_blog/posts/spacemouse-update-for-v10-drivers
Regarding support within MAXSURF you may want to inquire in that dedicated forum or submit a service request.
