I know that the toolbox that contains the Active Level Filters (in the Legacy Attributes toolbox) is still available in CONNECT and I have it docked, but I have all of the icons turned off so I just see the Active Level Filters icon. Looking at the Ribbon group for Attributes for CONNECT this tool is not available.
What I would like to be able to do is add Active Level Filter to a Ribbon group, but looking through the list of tools while customizing the ribbon I am not able to locate the Active Level Filter tool.
Is there a specific key-in to call up the Active Level Filter dialog? I know the key0ins to change the Active Level Filter from one to another, but what I want is to call up the dialog to have a picklist. This could be in a Ribbon Group or a Right-Click popup menu or even a function key.
I would rather not have a separate legacy toolbox open for a single tool when it could be incorporated into a Ribbon Group or Right-click menu.
Legacy Attributes
CONNECT Ribbon Attributes
For anyone else who may want to add the Active Level Filter to the Ribbon you cannot use the Active Level Filter tool in the Ribbon Customization option under the "Choose components from: Buttons". This button will only call up the key-in Active Level Filter which would require one other parameter, the filter name.
Instead you need to select Commands (Application) and select Level Filters. This will display a dialog with the Level Filters so you can select which filter you want to set active.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Answer Verified By: Marc Thomas
