I am trying to set up our Bentley Connect Workspace onto our network.
The first modification is a customized shortcut which includes the switch -wc"M:\Bentley\ORD\NetworkRedirect.cfg"
This file has one statement set in it:
#============================================================================ # Civil Organization Standard Location #============================================================================
%if exists (M:/Bentley/ORD/Configuration/CustomConfig.cfg) %include M:/Bentley/ORD/Configuration/CustomConfig.cfg %include C:/Program Files/Bentley/OpenRoads Designer CONNECT Edition/OpenRoadsDesigner/config/mslocal.cfg %endif
The CustomConfig.cfg includes
[General] _USTN_CUSTOM_CONFIGURATION=M:/Bentley/ORD/Configuration/ %lock _USTN_CUSTOM_CONFIGURATION
[SetConfiguration] %if !defined (_USTN_USER_CONFIGURATION) %if defined (_USTN_CUSTOM_CONFIGURATION) && ($(_USTN_CUSTOM_CONFIGURATION) != "") && exists ($(_USTN_CUSTOM_CONFIGURATION)) _USTN_CONFIGURATION = $(_USTN_CUSTOM_CONFIGURATION) %endif %endif %lock _USTN_CONFIGURATION
_USTN_USERNAME = $(USERNAME) %lock _USTN_USERNAME SHR_USERDIR = M:/Bentley/ORD/Configuration/Users/$(USTN_USERNAME)/
%undef _USTN_USERCFG _USTN_USERCFG = $(SHR_USERDIR)Personal.ucf %lock _USTN_USERCFG
I am getting this error message when I try to open the software:
Exiting, M:\Bentley\ORD\Configuration\Users\personal.ucf not found, [c:Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\config\msconfig.cfg], line 291
They aren't wrong...I do not have a Personal.ucf in M:\Bentley\ORD\Configuration\Users\personal.ucf. It is stored in M:\Bentley\ORD\Configuration\Users\mbloswick\personal.ucf Which I thought I was defining in my CustomConfig and locking.
Without this, I can't get any further in checking anything else, because without the UCF, ORD (MicroStation) just exits without any further processing.
How confused am I, and where am I going wrong? Thank you.
WARNING: This email originated from outside of the organization. DO NOT click links, open attachments, or respond unless you recognize the sender and know the content is safe.
oh shoot _USTN_INSTALLED_CONFIGURATION isn’t what you want. i think it’s $(MSDIR)config/mslocal.cfg
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
