[ORD 2020R3/Connect 16] Configuration variable definition order per MsDebug
I am going through my debug file, and I'm still sorting out configuration variables.
In msconfig.cfg I see:
# Include the workset configuration file if _USTN_WORKSETNAME defined.
# _USTN_WORKSETNAME can be set by (in order of priority):
#       1) -ww command line option.
#       2) operating system environment variable.
#       3) configuration variable.
%level System
%if defined (_USTN_WORKSETNAME) && exists ($(_USTN_WORKSETSROOT)$(_USTN_WORKSETNAME).cfg)
  _USTN_WORKSETCFG = $(_USTN_WORKSETSROOT)$(_USTN_WORKSETNAME).cfg
%endif
#  iF _USTN_WORKSETCFG is not defined.
#  check if active configuration has "NoWorkSet.cfg"
#  if active configuration contains "NoWorkSet.cfg"  define it to _USTN_WORKSETCFG
#  else
#  define _USTN_WORKSETCFG with the "NoWorkSet.cfg" present in the delivered configuration
%if !defined (_USTN_WORKSETCFG)
    %  if exists ($(_USTN_WORKSPACESROOT)NoWorkSpace/NoWorkSet.cfg)
        _USTN_WORKSETCFG : $(_USTN_WORKSPACESROOT)NoWorkSpace/NoWorkSet.cfg
    % else
        _USTN_WORKSETCFG : $(_USTN_INSTALLED_CONFIGURATION)WorkSpaces/NoWorkSpace/NoWorkSet.cfg
    % endif
  _USTN_HAVEWORKSET = 0
%else
  _USTN_HAVEWORKSET = 1
%endif
%if exists ($(_USTN_WORKSETCFG))
%  include $(_USTN_WORKSETCFG) level WorkSet
%endif
In my debug file, I see this:
(System): _USTN_WORKSETCFG=$(_USTN_WORKSETSROOT)$(_USTN_WORKSETNAME).cfg [M:\Bentley\ORD\Configuration\Worksets\.cfg]
This is very obviously not a viable workset cfg file. This faulty definition is confirmed in the summary of values at the bottom of the debug
_USTN_WORKSETCFG : System       = M:\Bentley\ORD\Configuration\Worksets\.cfg
                 : Application  = (null)
                 : Organization = (null)
                 : WorkSpace    = (null)
                 : WorkSet      = (null)
                 : Role         = (null)
                 : User         = (null)
but back to the debug itself, directly following the definition of _USTN_WORKSETCFG, I see:
Processing macro file [M:\Bentley\ORD\Configuration\Worksets\21-XX_KyTest.cfg]
Which is indeed the proper workset configuration. _USTN_WORKSETNAME is indeed correctly defined at the user level
I also see several other "workset" variables defined in msconfig, but not adapting to any variables defined later in the process.
I feel very confused. Can someone help me understand whether variables that may not exist when msconfig.cfg is run can be defined later, and revise the variable as defined, or if I just need to explicitly define them all "at level" as I go through.
I had thought I might be able to use a pared down workset cfg by "predefining" a number of variables based on _USTN_WORKSETNAME and _USTN_WORKSETROOT, but I wonder if that variable is defined too late for the bulk of my definitions.
  • I see what you see if I let MicroStation use the _USTN_WORKSETNAME and _USTN_WORKSPACENAME from my Personal.ucf. If I modify my icon to use -wkWorkspaceName -wwWorksetName then it works right from the beginning. (I also see the same null behavior for workspacename.cfg)
    The user cfg is included right before the  workspacecfg & worksetcfg variables are set but it's included at the User level. I'm guessing that may be why it doesn't get reported accurately in the debug? I assume this is some kind of debug error rather than an actual cfg file processing error?
  • For example my debug shows my personal.ucf being loaded and the workset/workspace names being set, then reports the workspace cfg file with jus that .cfg filename but then shows the Example.cfg for the workspace loading.
        Processing macro file [C:\Users\kvanhaaren\AppData\Local\Bentley\MicroStation\10.0.0_Kevin\prefs\Personal.ucf]
          (User): _USTN_USERDESCR=User [User]
          (User): _USTN_WORKSETNAME=MetroStation [MetroStation]
          (User): _USTN_WORKSPACENAME=Example [Example]
        End of macro file [C:\Users\kvanhaaren\AppData\Local\Bentley\MicroStation\10.0.0_Kevin\prefs\Personal.ucf]
        Starting skip to endif, [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\msconfig.cfg], line 341, depth = 0.
        endif, [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\msconfig.cfg], line 343, depth = 0.
        (System): _USTN_WORKSPACECFG=$(_USTN_WORKSPACESROOT)$(_USTN_WORKSPACENAME).cfg [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\.cfg]
        Processing macro file [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example.cfg]
          (WorkSpace): MS_DGNLIBLIST=$(_USTN_SYSTEMROOT)\dgnlib\*.dgnlib;$(_USTN_SYSTEMROOT)\dgnlib\DrawComp\*.dgnlib;$(_USTN_WORKSPACESTANDARDS)Dgnlib\*.dgnlib;$(_USTN_WORKSETSTANDARDS)Dgnlib\*.dgnlib;$(_USTN_ORGANIZATION)dgnlib\*.dgnlib;$(_USTN_WORKSPACESTANDARDS)DgnLib\*.dgnlib [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\dgnlib\*.dgnlib;C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\dgnlib\DrawComp\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\Dgnlib\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\WorkSets\Standards\Dgnlib\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization\dgnlib\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\DgnLib\*.dgnlib]
          (WorkSpace): MS_GUIDGNLIBLIST=$(_USTN_WORKSPACESTANDARDS)Dgnlib\GUI\*.dgnlib;$(_USTN_WORKSETSTANDARDS)Dgnlib\GUI\*.dgnlib;$(_USTN_SYSTEMROOT)GUI\Archive\*.dgnlib;$(_USTN_ORGANIZATION)dgnlib\GUI\*.dgnlib;$(_USTN_WORKSPACESTANDARDS)DgnLib\GUI\*.dgnlib [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\Dgnlib\GUI\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\WorkSets\Standards\Dgnlib\GUI\*.dgnlib;C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\GUI\Archive\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization\dgnlib\GUI\*.dgnlib;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\DgnLib\GUI\*.dgnlib]
          (WorkSpace): MS_CELL=$(_USTN_WORKSETSTANDARDS)cell\;$(_USTN_SYSTEMROOT)cell\;$(MS_SHAREDCONTENTDIR)cell\;$(_USTN_WORKSPACESTANDARDS)cell\;$(_USTN_ORGANIZATION)cell\;$(_USTN_WORKSPACESTANDARDS)Cell\ [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\WorkSets\Standards\cell\;C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\cell\;C:\ProgramData\Bentley\connectsharedcontent\cell\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\cell\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization\cell\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\Cell\]
          (WorkSpace): MS_MACRO=$(_USTN_WORKSPACESTANDARDS)macros\;$(_USTN_WORKSETSTANDARDS)macros\;$(_USTN_ORGANIZATION)Macros\;$(_USTN_WORKSPACESTANDARDS)Macros\ [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\macros\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\WorkSets\Standards\macros\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization\Macros\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\Macros\]
        (WorkSpace): MS_VBASEARCHDIRECTORIES=$(_USTN_WORKSPACESTANDARDS)macros\;$(_USTN_WORKSETSTANDARDS)macros\;$(_USTN_ORGANIZATION)Macros\;$(_USTN_WORKSPACESTANDARDS)Macros\ [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\macros\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\WorkSets\Standards\macros\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization\Macros\;C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Standards\Macros\]
        End of macro file [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example.cfg]
    Answer Verified By: MaryB
  • Debug errors do not help me debug my configuration...
    Let me file a Service Ticket on this.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
