configuration explorer
I have made several workspaces and worksets on my network. I address these through shortcuts with a commandline parameter -wr<Networkpath>. This works fine for MicroStation, but the Confuguration Explorer ignore this parameter so I can't check the desired workspace/workset. Is there a way to have Configuration Explorer configured to read this parameter or is there a work around to have Configuration Explorer looking in the desired network environment?
