In trying to setup both SCDOT and NCDOT workspaces in my Microstation GEOPAK, I've caused an issue that I can't seem to fix. When I start MS, this window opens with the mesasge "can't open macro file [C:\Program files (x86)\Bentley\PowerGEOPAK V8i (SELECTseries)\PowerGEOPAK\config\system\applicationload.cfg], [C:\Program Files (x86)\Bentley\PowerGEOPAK V8i (SELECTseries)\PowerGEOPAK\config\msconfig.cfg], line 115
What version of PowerGeopak are you using?
It should be there, but have you checked to make sure that the "applicationload.cfg" is in the directory listed? I've seen stranger things...
How did you set up those workspaces, and can confirm everything runs out of the box fine without them?
MaryB
