Cannot open v8i files from Projectwise. Getting lots of error 193's with .dll's.
I am trying to open a file on projectwise, but it is impossible with with a V8i program. I am trying to open it with SS10 08.11.09.919.
I have stumped my IT department. I have gone through and deleted all Bentley software, reinstalled, as well as restoring both V8i and CE to defaults.
I cannot even get Microstation to open the workspace configuration to see what happened, I have a hunch it has something to do with the MDLapps. I tried adding AutoTurn to Microstation Connect Edition by adding a line in the workspace configuration. It ended up not working and I removed it. Then this problem started with V8i
  • I cant test right now, but I can confirm that Microstation opens fine externally, and I can even open files in Projectwise if I do not restart the workspace. It is only if I restart it, or open the file from the ProjectWise explorer.
  • I suspect it's something in your projectwise workspace, or your program association causing the issue.
    • in PW Explorer go to Tools menu > Associations > Program Associations
    • Set the association view drop down at the top to User associations
    • Scroll down the list to MicroStation, click the + next to
    • Click the + next to Open
    • For each application under Open, right-click and select Unassociate
    Try opening your file again. Note that it's possible the dgn file has a different application associated with it than MicroStation, you can right-click the file, select Properties and see what application it's assigned to.
    If you know how to get a Microstation debug when using ProjectWise Explorer that would probably help too.
  • No associations on any bentley products.
    After verifying, I followed the steps here to get it to debug. It opened the text window, ran lots of text and i got "Microstation stopped working" I have attached both the text in the text window as well as the log from the "stopped working" window.
    Microstation Debug.txt
    exception.log
  • it's definitely an issue in your configs somewhere. I'd check your user config and see if there is anything in it that might cause an issue. It's hard to tell exactly where the problem is because the debug file is kind of messed up, presumably because of this issue. The exception log also shows variables and has and overall summary that is usually in the debug but is missing in yours.
    Looking at the exception log the varialbes that are messed up are:
    • MS_ADDINPATH
    • MS_MDL
    • MS_DGNLIBLIST
    Everything else seems ok. MS_LIBRARY_PATH for example is correct.
    You might check the C:\Program Files (x86)\Bentley\ProjectWise\bin\empty.cfg file and verify it has nothing in it (mine has a single comment line that it's a dummy file).
    It may also be loading the road.ucf from C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\users\
    That's probably about the limit of what I can parse out of this, you'll probably need your ProjectWise workspace people take a look at it, they should be able to generate a debug on a good machine and compare to yours. There may also be an environment variable set that is screwing this up.
  • Yes, those are the variables I changed in connect edition to try and get autoturn to work.
    Could it be that CE edited the V8i config, and overrode with its own settings? As I have deleted and reinstalled all the folders, it leads me to believe somehow something on the server side for the workspace got messed up, but other people can open files in the same workspace just fine. How do you tell which .cfg it is pulling those variables from?
