Hi.
I don´t understand one thing.
When I create a Workset and a new DGN in it and I add toolbars in the drawing and do "Save settings" (although "Save settings on exit" is activated) then is OK.
If I create a new drawing in the same Workset I get the same toolbars. OK
But if I create a new Workset and a new drawing in it I don´t get the toolbars. I understand that "Save settings" is saved in the same DGN but also in the current Workset.
Is there any way to copy/paste (or import/export) the "Save settings" in a drawing file to another drawing file? or another WorkSet?
Can I edit the ASCII file Workset.config to copy/paste the "Save settings" between them?
Or do I have to put the toolbars in the seed file and "Save settings"?
Maybe I could save the toolbars in a new WorkFlow but in my case I have "Drawing" and "OpenRoads Modeling". I don´t know if I can add toolbars for both WorkFlows at the time.
Open Toolboxes are stored in user preferences, so something in your configuration is saving the UPF with different names. What is your context? Are you working on a networked configuration or locally?
Marc
