I use microstation 08.11.09.578, DGN 2D V7 Upgrade V8
After successfully exporting the KMZ file, a popup will appearI want to turn this off, is it ok, when I do other things like watching movies it turns on very annoyingI went into settings but couldn't find it
HI,
you should ask in some general Windows forum, because it is not MicroStation dialog, but Windows.
It would be interesting to know what exactly you did, because by default, MicroStation only saves exported file to specified folder. It does not try to open it, so there should be some extra action in your workflow.
With regards,
Jan
