[V8i] Is it possible for a Pop-Up Screen Menu to display Full Screen?
I'm currently doing some testing with a custom Screen Menu, my preference is to use the 'Popup' style as when displayed, they are not constrained within a view window, and I dislike the default type with its Window Frame/Titlebar and size-adjustable window.
What I would like to do is have the Pop-Up Screen Menu display and fill the entire screen of my choosing, but I seem unable to do so. I have the boundary frame geometry sized to match my monitor resolution (1920x1080) and have created a Saved View, yet the size of the Pop-Up Screen Menu when displayed, is not what I want.
I am aware of what the help file states regarding size:
"Set up the window size and menu size as you want to see it. The saved view represents how the screen menu looks when it is activated. If you do not create a saved view, a default size is used for the menu and the display parameters are those that were active when Save Settings was last performed on the model."
What I was hoping to do was select the Saved View and be able adjust its screen display size via Element Properties, but that appears a dead-end. I also cannot seem to find any other method exposed through the GUI where the displayed size of the Saved View, could be manipulated.
I am wondering if there is some obscure key-in which could do it, or if its possible programmatically?
