There have been other questions here about having MSCE open ORD configurations, which is not really a problem by itself, but now the plot thickens....
This is a bit long, but stay with me, some of you may be facing the same issue.
Within the past week I have been contacted by two clients about setting up the MicroStation configurations so that they can utilize WorkSpaces from different versions of ORD, and also accessing non-ORD based configurations.
The situation is as follows...
How do you configure MicroStation to access three different sets of standards stored under three different Configurations?
The solution I have come up with so far is:
This seems to work well, however...
DOT A also has older projects in ORD 10.9 that are not being moved to ORD 10.10. How can I tell MicroStation to access the ORD 10.9 WorkSpace instead of ORD 10.10?I can't change the WorkSpace name because the dgn's are branded to the other WorkSpace name, changing the branding would introduce all sorts of other problems.
I also haven't tested this with any ORD configurations that implement Roles. That might be another sticking point.
Anybody else having the same problem?
I know it is only theory right now , but I was basing it off of the naming convention you used for your folders.
You have it defined with the product and the version - so I thought OBM would be set the same way.
Timothy Hickman
Main: 877 627 3772|
That's probably OK.
For the DOT's that roll out their configurations this way, they are upgrading both ORD and OBM at the same time. Then you manage the OBM _USTN_CUSTOM_CONFIGURATION the same as you do for ORD.
I guess the other thing is I haven't run into any client using OBM who isn't also using ORD. I also haven't had any requests so far to access OBM only WorkSpaces from MicroStation.
I'm sure that day will come too.
Rod WingSenior Systems Analyst
I have no suggestions whatsoever, but thank you for a very clear example of the nightmare created by versioning and branding.
MaryB
It's rather curious that Bentley updated their Wiki page about the One Configuration today.
https://communities.bentley.com/products/administration/w/wiki/56590/one-configuration
One Configuration sets up automatic %include statements for including resources from different applications, but doesn't really help in this situation.
Rod Wing said:DOT A also has older projects in ORD 10.9 that are not being moved to ORD 10.10. How can I tell MicroStation to access the ORD 10.9 WorkSpace instead of ORD 10.10?
The only workable solution I have to this problem is to create a separate MicroStation shortcut with a -wc switch that uses a startup configuration that sets the value of _USTN_CUSTOM_CONFIGURATION to the the ORD 10.9 configuration folder. It's not pretty, but it works.
