'File' Dialog Is Extremely Slow
Hi All,
We have recently moved over from V8i SS3 Microstation to Powerdraft Connect. We have found that the 'File' dialog (below) appears to be very slow. Obviously, with the frequency we use this dialog, it is having a cumulative impact on our work. Are there any settings that can be turned off to make this dialog appear more rapidly, such as turning off file previews or can we switch to a simpler more traditional file drop-down instead of the overlay?
For me, the file button takes about a second to appear once clicked. For one of my colleagues working remotely via VPN it takes 10-15 seconds. I assume it must be something to do with the file previews?
Any help would be much appreciated.
Ben
