I am trying to recreate some customizations from an older version of Microstation. These were a barmenu and the keyins for the tools within the menu called .mdf files. I converted the .mdf files to .xml. I've read some forum posts that state you can import .xml files into the ribbon customization. I attempted to do this and when I use the Import From XML File in the Customize dialog I receive a message that the import was successful. However, I do not see any new items listed in the Customize dialog boxes. Where are these .xml imports located at this point?
can you share the mdf files? you may have to change the file extension so its seen as a txt file and use the import data tool in excel to format how the data is brought in. I believe the tool is called Text Import Wizard
I can provide some .mdf files but I am not able to post them to the forums. How can I provide them to you?
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
you can use the following link:
bentley.sharefile.com/r-rd5d4eb3809014da286dcebb906b1c0cb
Thanks, files have been uploaded
